Light connectors - no earth
19 Feb 2007
Bristol
I want to fit a wall light to the top of the stairwell in my flat. There was previously some kind of light fitting there which looks like a bedside lamp stuck to a wall! Have removed the previous fitting and there are just the 2 core wires coming out of the wall into a terminator block.
I can't see an earth although looking on the other side of the wall and above - there is an old ceiling rose without a cord hanging down. I wonder if the person who converted the flat has take the L and N and extended the wires to the outlet in the wall where I want to fit the new light.
Is it safe to fit without the earth and I'm guessing it's probably not as the new light has a metal base on it.
How do I go about earth the new fitting.
Thanks in advance.
Thanks in advance.
As you rightly say, if the new fitting is class I, which it without doubt will be if it has a metal base with an earth connection, then you cannot fit it. You will either have to replace the existing wiring right back to wherever you can pick up an earth from the same circuit, or buy a class II double insulated light fitting that doesn't require an earth. You may get lucky and find that the cable in the wall is actually twin+CPC (earth) with the CPC trimmed right back.
Worth noting that even if you do find an earth in the ceiling rose, I'd be a little dubious about whether or not it's connected at the other end if the wiring is old and/or has been fiddled with by a previous DIYer. Of course, without an earth loop impedance meter, you have little means of testing it properly.
You may want to check the rest of the lighting circuit for the same reason
Thanks guys.
Bought a double insulated light, fitted and all works fine.
