Light Fitting Advice
all you need is an extra connector
the sleeved blue / brown wire goes in the L terminal
the blue wires go in the N terminal
the green / yellow wires go in the Middle / earth terminal
and finally the three brown wires go in the extra connector which is the live loop
thanks for the quick reply. the connector that the loop currently goes into is removable from the old fitting. could i simply reuse that and follow the same sequence with the new light?
Providing it is big enough then not a problem :)
