Hi, Hopefully someone can help...the problem is I have installed a new light fitting and it comes on when the switich is in the off position and vice versa - I have installed another fitting in the same loop which is working fine.
Bit more detail...
I have bought two ikea light fittings (never again not worth the bother) to go in my open plan living/dining room. the existing fittings are part of a 3 light loop. the ceiling rose had one cable going to live, 2 to neutral and 3 to loop and 3 to earth. Upon removing the ceiling rose I had 3 grey cables, each with one red, and one black wire in them. the light fitting has only a L and N so I have put the 3 earth in a terminal block, 3 loop wires (red) in a terminal block, two neutral (black) into N and live (black with red sleeve) in L. is this correct?
The 2nd light fitting seems to be working fine and the other light in the loop is also working. I also can't remember if the light switch was the 'wrong' way round before I started messing about so could it be an old fault?
Many thanks for any help
Bit more detail...
