Light problem on Bosch KUR15A40GB built-in Under Larder Frid
30 Sep 2011
Hi all,
I have a Bosch KUR15A40GB built-in under larder fridge. The bulb blew recently, which I have replaced. The fridge still works fine, but the light will not come on.
I'm hoping there's an internal fuse which has gone, but I can't get into the unit which the bulb screws into. Any ideas on what could be wrong, or how to get into it?
Cheers,
Neill
Yes, thanks, bulb checked and double-checked. Works fine. Definitely a fridge fault this time.
Don't think there is a fuse, so suppose switch faulty, used to be able to look at wiring diagrams on Bosch site, don't know if you still can, have a look. Is the light switch in the thermostat housing or in the liner?
Colin
I have checked the door-switch, and it works fine (large change in resistance when the button is depressed). I cannot find wiring diagrams on the bosch web-site. I've looked on google images - those that there are do not mention a fuse. However, this is moot, since I have no way to get into the light unit.
Thanks for your help,
Neill
