Help needed please.
I replacing some light switches which I have done many times but not seen this setup before.
Basically I have 2 x 2 gang switches.
Switch 1 (by the front door) gang 1 controls outside the light, switch 1 gang two is the first in a two way switch for the hallway lights (2 pendants).
Switch 2 (at the bottom of the stairs) gang 1 is the second switch for the hallway lights, second gang is the first switch of the landing lights.
All as expected so far. However when I look at the rear plate of switch 1 by the front door I'm seeing something odd. L2(right) = RED, L2(left) YELLOW with a red sleeve so switched live. However the two L2's are connected to each other by a short red wire.
COM(right) has no wire. COM(left) RED wire.
L1(right) = RED, L1(left) = BLUE with RED sleeve and a YELLOW with a RED sleeve
Switch 2 at the bottom of the stairs, with the other switch for the hallway lights has COM = RED, L1 = BLUE with RED sleeve and L2 = YELLOW with RED sleeve.
What is happening is that either switch will turn on the hallway lights, but the opposite switch will not turn them off. Only the switch that turned the lights on will turn them off. The other gangs are doing what I expect e.g turning on the outside light, or the landing light.
Basically, I have tried moving the terminals around, but it makes no difference.
Any advice would be hugely appreciated!
