We've had a combi-boiler fitted, so don't need the hot-water tank. That's gone, as has the airing cupboard it was in (in the bathroom). I'm now going to install a shower in place of the airing cupboard, and inside the shower I want to install some GU10 ceiling lights - I have proper Zone-safe ones.
Floor to ceiling height is 2250 mm.
I have re-wired the main light off a fused spur (on the ring main), that also carries a wall-mounted fan-heater that operates off the same heavy-duty ceiling pull-switch (with its own in series).
So from that switch (via a JB of course) I have taken another lead to another JB to feed the GU10 lights over the shower.
But "it would be nice" to have those also operated by their own switch in series. I propose to use the old light-duty ceiling pull-switch. I guess I'm not allowed to mount this actually inside the shower enclosure ?
If that's the case, then can I mount it over the adjacent bath ?
And if not there, how close may it be to the shower enclosure ?
Another alternative is to mount it on a rafter in the loft, with just the string coming through the ceiling, in which case I guess I can put that string anywhere I like, even inside the enclosure ?
But it I do THAT, I need some kind of plate on the ceiling with a hole in it to prevent the string from wearing away the plasterbaord ! And I haven't seen ANYTHING like that on the shelves !
I would replace the string with a basin-waste chain, I think
