Light Switch
21 Apr 2010
Staffordshire
I am changing a two way light switch from a pull switch to a traditional switch. The switch is mounted on a plastic conduit patress with no earth.
What do I do with the earth wire?
Other style boxes have an earth terminal, so do it just connect the earth wire to a 5 amp terminal block?
Which room is the switch in?
How will you extend the cables?
Where will you run the cables?
Are you aware of the law regarding Building Regulations approval for some electrical work, and what the Wiring Regulations say about junction boxes and routes and RCD protection for concealed cables?
What difference does that make, do different rooms require the earth wire to be terminated in different ways?
I don't have to, there's enough cable to move the switch.
Er, down the wall I guess.
What law do I break by changing a switch and not getting building regs?
Since I'm not using any junction boxes or concealing any cables, way should that be an issue for me?
No, but some work in some rooms requires Building Regulations approval when it wouldn't in other rooms.
Fair enough - it's just that it's unusual for there to be enough spare cable to move the switch position from the ceiling to the wall.
Quite possibly the Building Act 1984.
Fair enough, but see above.
It's unusual for there to be enough spare cable to be able to move a switch from the ceiling to a wall, and it's unusual for people to be happy with cables running down the surface of the wall, i.e. not concealed, that's all.
