I have a double 2-way light switch. I've installed phillips hue bulbs and want to blank out the switches with a blanking panel and then mount wireless Philips switch on the blanking panel. I can mount the wireless switch over the switch using an adaptor but this makes it a little too bulky. Can I use terminal blocks to wire the wires inside so that the bulb is wired to always be on? If so how would I do it as it's two way. I have L1, L2 and common on both ends of the switch
