Light Wiring - where does the swich wire go?
10 Jul 2003
I've just bought a new light for the bathroom, which has 3 terminal blocks in it. Live, Neutral and Earth. In the existing ceiling rose, which i will remove in order to fit the new light, there are these three, but also the switch wire. Where should i put this switch wire in the new light.
Ian
the "live" that you hve is a loop in terminal (just there to connect wires to) your actual light should go across neutral and switch wire.
