lightbulbs are constantly blowing!!!!!!!!!!!!!!!
23 Jan 2012
Shropshire
can anyone give advice as to what could be the probable cause of my lightbulbs constantly blowing.it happens in any room,and a bulb will blow approx once a week.the only thing that i have noticed is that it seems to only happen more often when there is more than one bulb in a configuration. i.e a chandalier with 3 bulbs in or lights on side of wall in sets of 2.could this be just coincidental?
any help would be great!
regards
zac
Cheap lamps or tired lampholders or voltage surges or a loose connection.
For my education, you you perhaps expand on how tired lampholders and loose connections (assuming lamps are not flickering on and off - which prresumably would be noticed!) reduce the life of a lamp?
Kind Regards, John.
Why do my lightbulbs keep blowing?
Relax !!! This problem does not mean you have a major wiring fault. This is a never ending problem which has been looked into for donkeys years. A wiring fault in your circuit will be picked up by fuses and MCB's long before it gets to the bulb.
There are a few reasons bulbs can blow, the major one being cheaper bulbs. The elements in cheap bulbs are much thinner and any surge of power, however slight, simply breaks them. Always go for expensive light bulbs, its cheaper in the long run.
A loose connection in the lamp holder can also cause bulbs to blow. This is because the circuit is not completed as tightly as it could be and the electricity may have cause to “arc” or jump across the contact, rather than simply flowing through it. When this happens it produces more heat in the fitting than is expected or catered for by the bulb, and the bulb can blow.
The same can happen if the spring loaded connection in the bulb holder is slightly loose. This will cause electricity to arc across the contact, cause too much heat and blow the bulb. This can very often be diagnosed by looking at the contact on the bottom of the bulb to see if it is pitted. Arcing electricity effectively melts the metal it is arcing onto ( This is how arc welding works) so if the bulb contact is being subjected to arcing, tiny little indentations occur, called pitting.
It is sometimes possible, if the live connection in your light switch is a little loose, for this to happen here also. Heat will be generated and it is possible, though very very remote, for the bulb to blow as a result of this.
When a bulb blows, 99% of the time the MCB for the lighting circuit will blow or trip also. This makes the problem seem rather bigger than it actually is. The most common reason a burning out bulb pops the fuse is that just after the thinned filament vaporises there is enough metal vapour in the envelope to create a tungsten vapour lamp between the filament supports with a very high current as there is no control gear to limit it. Design means there is no way the tungsten vapour lamp can survive as the vapour spreads to fill the rest of the bulb and becomes too dilute to support the discharge.
With some very small bulbs, the capsule type, the tungsten vapour can maintain the discharge long enough for the bulb to explode.
So, three things to look into if your bulbs keep blowing. Your bulb supplier, The wire connections inside your bulb holder, and if the spring loaded connectors are working properly inside the bulb holder. As a last resort you can also check the tightness of the connections in your switch.
In the case of quartz (halogen) bulbs the slightest bit of grease or other deposit on the glass will accelerate failure of the bulb by seeding crystal growth in the glass when it is hot.
Never handle quartz bulbs with bare hands, use a clean tissue.
Another way to improve lamp life is to install CFLs (low energy light bulbs)
What type of bulbs/lamps are we talking about?
What are the makes of the bulbs/lamps?
Generally it is normally the use of cheaper, lower quality bulbs/lamps which is the cause. I would always recommend spending a bit more and on a better quality bulb/lamp.
And don't forget if you've got a fitting whitch takes 5 bulbs, then you will be changing bulbs 5 times as often as you would with a traditional single bulb.
Another cause is vibration.
If there is movement of the light fitting due to folk on the floor above then this will have a detrimental effect on lamp life.
Did a job last week. Ceiling light fitting downstairs had 5 x 40watt tungsten candle lamps in it.
In the bathroom upstairs, Pat & Mick were ripping out the bathroom (included breaking up a cast-iron bath).
Later that day it was found that only one of the lamps still worked.
Another thing that can cause lamps to burn out quicker than expected is if they are at an angle.
I'm a little late to the board, but i have the same problem. I built my house in 2001, and since day one, I've had a bulb blow out once every week or two. It happens in all rooms, bedrooms, garage, basement, hallways. I've tried using high quality bulbs, cheap bulbs, even the eco-friendly bulbs. The only bulbs that seem to hold up are the fluorescent bulbs that I have in the basement and laundry room. I just replaced 2 out of the 3 light bulbs in my garage about 2 months ago and yesterday 2 more blew out. I don't know what else to do.
Swap as many as you can for a quality brand of CFL.
I use Osram, don't know if they are widely available across the pond.
Mine are all at least 2 years old (18 months for the LED's).
What voltage rating are your lamps?
What actual voltage is your supply? I know it is supposed to be 120V +/- 10% so that is a range of 108 - 132V. Might be worth checking it is within spec.
Have you definitely changed replacements recently ?
Could be you've ten lamps all at the age they are going and still have a few old ones left in service. Uncanny but proved this years ago.
Another contributing factor is our UK voltage level. Most of our lamps are made abroad these days, so are made for 220-230V (which means they are built to the lower end of the manufacturing standard, as are most things). Despite our UK voltage being nominally 230V, the substations still knock out 240V and often more. So you have a low-quality product getting hit by more power than it's built for.
pj
pj
UK voltage has always been 240 volts. It is now called 230 with a wilder tolerance to satisfy the Eurocrats. Likewise in Europe it is still 220v but called 230v.
CFLs are very tolerant of voltage variations. I have been in parts of USA where voltage fluctuates a lot and lamps don't last long. So I recommend they get energy-saving lamps.
they also last 5-10 times as long as filament bulbs, and use less electricity.
So why not try them?
