lightening up dark woodwork
22 Jun 2004
I have some very dark mahogany coloured woodwork to lighten up,will take ages to sand down and revarnish as was previously stained and has gone deep in the wood.Any suggestions bar a coat of gloss over it.
Thought about one of those paint and grain kits but can not find one.
Dulux also do a product called 'brushwood', you can get it in different finishes, oak, teak, beech etc.
It comes in two parts, the first part is waterbased, and gives you your base, if your going from dark to light then you would need 2 coats of this.
The second part is your coloured varnish, the down side with is that the varnish is quite glossy, but if that suits you then okay.
I have used this over existing white paint for the client, as they wanted thier staircase to tie in with their stained woodwork in thier lounge.
I must admit, it went very well, and its difficult to see which is the real stain and which is the pretend one.
If its done right, it can look quite nice, but I dont like the glossy finish, but you can then sand the gloss coat back a bit, and apply an ordinary satin varnish to dull it down, again I did this on another job, and it took very well.
You can buy paint and grain, and brushwood from 'Homebase', I got some about 2 months ago, (brushwood) I saw only the paint and grain in B&Q the other day.
So it is out there. :D
If you want to keep the beauty of the woodgrain then best to use oil products
I agree, but you cant stain over a dark stain and make it lighter, unless you strip the old stain off, the brushwood and paint and grain are made to do this.
Found a paint and grain kit at focus,antique pine,the small area I treid it on has come out well so fingers crossed for the rest.
