Hi, I've got a 2009 built flat that came with some pendant lights and I set about replacing them with some fixed (bulb not replaceable) Aurora M7 LED downlights
I daisy-chained the new downlights to the existing feed. At the time I noticed the existing feed was 1.5mm2, though my new wire for the daisy-chaining is 1mm2. The cable runs through a suspended ceiling and isn't covered in insulation or anything
An electrician I've spoken to more recently said this wasn't a good idea, and that you should never change the diameter of the cable mid-way on a circuit.
The lighting circuit is on a 6A breaker
One set of lights has 8 x 7W lamps, the other has 6 x 7W lamps
I figured that the 1mm2 is fine for the 6A load. So is this electrician right or am I? Put another way, if I asked an electrician to sign off these minor works, would he be able to do so?
Thanks!
Thanks!
