I live in a small two bedded house with a single lighting circuit that covers all 8 lights in the building, upstairs and down, and has no earthing. It looks very old - red and black PVC. A couple of questions arise:
1. Is it essential to have separate up and down circuits for lights? The reason I ask is because splitting the circuit is not possible without changing the consumer unit for one with additional breakers. Can I just stick with the one circuit, given the low number of lights (800W, if all 100W bulbs, but actually is now about 250W due to CFLs)?
Upstairs is pretty simple - there are four lights looped with connections in the ceiling roses. The end of the lighting circuit is in bedroom 2.
2. I imagine replacing all the circuit cables with 1.5 T+E running over the top of the loft insulation, and 1.00 to the switches would do it. Does this sound right?
Downstairs is more complicated. There are 4 lights, plus the feed to the upstairs part of the circuit. I haven't fully traced the wires yet (furniture) but I have found a junction box under the floorboards which definitely feeds the upstairs part of the circuit (1) and, judging by the number of wires leading from it, has the switch and power for the kitchen light coming into it (2,3) as well as power coming in (4), which may be via a loop into either the hall or sitting room light, or both. Then there is a fifth 1.0 twin...
3. Does Consumer unit to loop into hallway, then loop into pantry, then loop into sitting room, then junction box to kitchen, and finally upstairs sound like a reasonable plan? It's a longer cable run (the circuit goes to the sitting room light and back on itself to get back to the junction box), but it avoids having more than 4 wires going to the junction box...[/b]
