Hi.
Last night the downstairs lights all went out, I checked the Circuit Breaker (Fuse), that was ok (the outside light worked when I after I broke the circuit then reset the switch)
My question is could this be a loose connection at a rose?
I replaced the roses on the two lights in the hall about two years ago, the only other thing which has happened is if a halogen spot lamp fails then the breaker operates.
I hope to be able to check them this evening if I can get off work early enough
