Hi, I have a problem with the lighting circuit in my house. Firstly it is an overhead supply and, in order to build an extension I had to remove the earth rod from the ground and I have yet to replace it. The power to all MCBs is supplied through an RCD. Yesterday whilst moving an armoured cable the RCD tripped and would not reset. I turned all the MCBs off and the RCD would still not reset. I then removed the red and black cables from the lighting circuit as this cable was the one I disturbed when I moved the armoured cable. I was then able to reset the RCD and power came back to all other circuits. When I reconnected the red cable to the lighting MCB nothing tripped but when I touched the black cable on the neutral bar connection the RCD tripped and would not reset. About three weeks ago I had to replace the RCD unit itself after a thunderstorm. I disconnected the three leads from the lighting MCB to a spare MCB and when I connected the red cable the RCD tripped out again. I fear I have damage to some cable in the lighting cable but how do I find it if perceived wisdom decides this is the problem. Is there a meter I can buy which will help me test sections of this circuit ? I have a reasonable amount of knowledge and can work safely. Help.
