Can anyone tell me why lighting isn't generally wired as a ring and whether there would be any advantage in a ring if the physical layout meant that it was easy to do it?
What do you expect to gain from wiring the lighting circuit as a ring?
From my above post you can see the Ring Circuit isn't such a brilliant idea.
Actually it does matter where things are plugged in - that's one of the drawbacks of rings. With radial circuits it doesn't matter because they don't have unbalanced undersized cables in parallel supplying each point.Personally, I think, for sockets, rings are a good idea, it doesn't matter where the high current draw (fire) is plugged in.
As a plus its easier to do your continuity/R1+R2 tests!!
Have you never heard of MCBs and fuses ? Believe it or not these operate or melt long before the copper in the "overloaded" CPC can melt.And exactly the same "feature" is twice as likely to be a disadvantage (as there are 2 live conductors vs 1 cpc) and get you a potentially overloaded cable.
Ib ≤ In ≤ IzHave you never heard of MCBs and fuses ? Believe it or not these operate or melt long before the copper in the "overloaded" CPC can melt.
No, I'm saying that if you get a break in L or N continuity you suddenly have a 32A radial using 2.5mm² cable.Or are you saying that with two live conductors leaving the MCB there can be twice the MCB's rated current coming out of the MCB terminal ?
