Lighting ideas
12 Apr 2010
Kent
I have around and over bed wardrobes. The over bed units are 1600mm wide and the bed is ~1400mm wide so I have some filler strips either side (the bed is not right back against the wall as there is a slim shelf).
I want to put some recessed LEDs in the side filler strips and some "puck" LEDs to sit on the shelf, but want them to be;
fairly dim at max brightness
the recessed to super small diameter and from the wall to the face of the filler strips is about 135mm so short length (~100mm to allow for cable bend)
the pucks to be fairly small diameter (depth of shelf is 135mm)
RGB capable
Voice and app controllable only (no switch and using Google Assistant/Home) - preferred as one group for all of them (thinking 2 in the shelf, and 2 in each filler strip)
everything has to have a frosted glass diffuser as I hate the look of exposed bulb fittings
Is that available? I would settle for the shelf having recessed as well.
Thanks very much
I've just come across "fibre optic" lighting. Anyone know about that?
As an alternative can you get a really small touchless sensor with a short contact for a light switch. Something that you hover your hand over
I'd rather not mount an 86x86mm standard switch!
