I recently purchased a property in England, west Yorkshire and called in an electrician to certify the electrics. He told me that:
1- The MCB fuses in the consumer unit need to in order of High to Low.
Is this true? Has anyone come across this?
Please can someone kindly help me with the following questions:
Q1 – I have read on the internet that light switches and mains sockets have to be at certain height.
The height for mains sockets has to be 450mm from the floor.
The height for light switches can be upto 120mm- maximum.
The property I have some of the light switches are above 1200mm and some of the main sockets are above 150mm and below 450mm. Do I need to re-install them? Is this a mandatory requirement nowadays?
Q2 - In order to install a wall mounted lamp holder (with 3 terminals earth, live and neutral). Can I take a mains to a switch and then to a wall mounted lamp holder. Is this OK and does it conform to 16th edition? If not what is the recommended approach?
Q3- In lighting loop or ring mains - Can you put a junction box to add in a new socket or a new light? If not what is the alternative?
Q4 - I have experience in domestic electrical installation and would like to become a certified competent electrician. I don’t wish to spend 4 years at a college. I have seen a number of quick part P and other electrical courses that can be completed in 5 days to 15 days in total. Is this true or just a money making game?
Many Thanks
Many Thanks
