Help, I am a competant DIY person, but this simple task is now the bain of my life
Bedroom lights swapped over. easy enough? NO! i must have done the classic and lost a switch live as no bedrooms (3 number) worked.
After a while with a multimeter i found the switch live in the first bedroom.
This has been connected and i have the light working
Lights don't work in other 2 bedrooms (1of them i never touched)
I started to look for continuity in the 2nd bedroom where the light was removed.
I have 2 reds (together) and only 2 blacks (separate) (plus earth) in this room. it is on a dimmer switch which i changed over for a normal one, in case that was faulty.
240V on reds in ceiling rose / switch and 150V at switch when switched on. I cant find continuity / switch live for love or money. i have had a couple of gueses and the light still wont work. It did however, start switching the first room wired earlier. so I put all back as original.
(2 reds in block and 2 separate blacks.)
Could the first light i wired be still faulty although working?
2 blacks in floating block connected to blue lamp holder
1 black (switch) connected to brown lamp holder
3 reds all together in ceiling rose
Earth - No issues
is the reds together causing me the problem? Im sure one was by itself previously
what is going on????? 2 minutes marking up at the beginning would have saved me all this aggro!
Earth - No issues
