Starting a new post it's following on from this one:
//www.diynot.com/diy/threads/porch-outside-light-switch-wired-to-sockets-circuit.424852/
basically lights are wired to socket (get live feed from them) and the current switch is a standard on/off switch with a fuse unit and people have kindly explain the need in the other topic.
but i have a new question/query i need help with, think i've found the hardware to use now.
i've got one of these:
http://www.maplin.co.uk/p/lightwaverf-in-line-relay-n64ll
however the fuse in this is 13A and the fuse in the current switch is only 3A... i assume i should replace the 13A with the 3A one BUT they are different sizes?! one in the relay is smaller. why are they different size? just aesthetics or a functional reason?
also as this device is fused - will this still do the same job to protect lighting?
Thanks in advance
P.s. sorry for such a rookie question
Thanks in advance
