Lighting Spur
I
Igorian
Hi chaps
I've taken a spur from the ring in my workshop to a FCU to power a single light (100W). I now want to add a security light (500W). I know that for sockets, you can't have a spur from a spur, but does this also apply to lighting circuits or should I run a new spur with separate FCU for this?
I believe it's generally okay to run two things radially off a fused connection unit, providing the fuse gives adequate protection (in this case a single 3amp fuse will).
Providing they are fed via the LOAD terminals, not the FEED ones....
ZenStalinist said:
well, duh!
There has been at least one post here from someone who did not know what "supply" and "load" meant...
But anyway - apart from the terminals in the fuse carrier being live even though the switch is off, it doesn't matter which way round you wire an FCU...
