After reading around this website regarding lighting cable in lofts I am very confused. Advice varies from loose cables over insulation to clip on joists under rockwool and "its not right but it'll be OK".
I am boarding the central part of my loft to allow access to a new boiler. The joists have been filled with rockwool, and then 2 layers of Knauf Space Board/Polyfoam has been laid, topped with 18mm chip. Other areas will have joists filled and then cross laid with 170mm rockwool.
What is the CORRECT method for installing 1.5mm T&E for lighting given that the flooring is for access.
I am really looking for a definitive answer, what the regs say, not what I can get away with.
