Have a sort of similar light fitting to this, except each buld is a smal 12v g4 that holds around 10 bulbs... If all 10 are in it is actually not as bright and sometimes the lights flicker when turned on or will not turn on at all.
If i take 4 bulbs out. Everything works fine. Is there too much power for the system to cope with. Also have spots in kitchen, one keeps blowing and another goes out and lights back up again on its own free will. I tried buying lower watt bulbs but the same still happens..
Any advice.
[/img]
Any advice.
