Hi there. I installed some new lounge lights yesterday (3 bulb chandelier type) as the wife has given me a headache about getting rid of the spotlights we inherited.
There are three sets of lights in the lounge/diner which work off a two gang brass dimmer switch. I fitted them all up and they worked fine, except that the dimmers won't dim. They will only come on with full power.
A couple of weeks ago, I changed the spotlights in the kitchen for a fluorescent light fitting. After carrying out this change all was well, and everything worked fine.
Tonight, we had the fluorescent light in the kitchen on as the same time as the new lights in the dining area. When the wife switched off the fluorescent kitchen light, the lights in the lounge/dining area blew. There was a bit of a bang from the lounge light fitting as it happened and the fuse in the main fuse box switched off. I took the light fitting off, and could smell a smouldering smell inside the light fitting. I checked all the wiriing, wired it all back up, and it did the same again when the kitchen light was turned off. What I dont understand is that there's a downstairs wc between the kitchen and lounge/diner, yet turning that on and off, or any other dowwnstairs lights doesn't cause a problem. It's just when turning off the fluorescent kitchen light. It has happened with two different dimmer switches, and the smell coming out of the switch seems to be coming from the live wire.
Independently, all the lights turn on and off fine, but it's only when the fluorescent kitchen light is switched off while any lights in the lounge/diner are on that these lights blow from the switch. The bulbs themselves aren't affected and will all work fine when the power is turned back on.
Can anyone tell me what may be causing this? Please let me know if you would need any more information to diagnose the problem.
Thanks for your help.
