A circuit, fed by 10A MCB (old wylex), the light turned on/off by 2 way switches (each in an end of the corridor).
with no clear reason the lights gone. The MCB trips intermittently, but not wen I was on site, I swapped the MCB with another one = same, checked continuity (by connecting the phase and the neutral in the CU and measured at the switches and the lights connection = OK. Although at the CU where the cable leaving the MCB I measure 237V, nothing reaches to the switches, or to the lights.
I did not have with me a 2 way switch.
Any ideas?
Thanks, Albert
Any ideas?
Thanks, Albert
