Hi, I've purchased some outside lights (simple wall lights with 40w bulbs) to replace existing bulkhead style ones. The new lights are double insulated (not that I think this is critical - just background info). The instructions state -
"Do not wire this light into the lighting circuit, use a switched fuse spur"
Am a little surprised - hence my post....
The lights I'm replacing are as follows:
1) One light I'm replacing is attached to my garage - this is connected to a pull cord and directly into the CU in my garage.
2) A single light attached to the back of my house, with a dedicated switch - this is connected to the lighting circuit - tested by removing the fuse in the CU for the lights.
3) 3 other lights are controlled by a single switch and also connected to the lighting circuit.
Can someone please explain to me why a light should not be connected to the lighting circuit? Is it simply due to the possible installation complications (for some people) of having more than 3 wires involved? In this case would it be OK for a competent person to install?
Adam
Adam
