- Joined
- 11 Apr 2009
- Messages
- 8
- Reaction score
- 0
- Country
I've recently had a new consumer unit fitted - the old 'fuse' one gone and a RCD one installed (Clickit with 2 sets of RCDs) - however I now get an intermittent problem:
A couple of nights ago when I switched a light on the 'other' set of RCDs tripped i.e. not the set that the lights are on - this light switch controlled a couple of Fluorescent units (the fault was repeatable) and I found that if one of these was isolated the problem ceased.
But tonight when another light was switched on the same thing happened but the fault couldn't be repeated.
It might be worth mentioning that the house was 'flooded' from a burst pipe in roof a few months ago (we've only just moved back in after major building works to correct this) and not all the switches were changes - could this be the cause?
