I have some outside lights that are controlled by a timer. This has been working fine since we started using them (wer'e new to the house) however, yesterday I noticed that they were on when the timer should have switched them off.
Adjacent to the timer is a switch with a cable (3 core and earth) running to the timer. Usually this switch would turn the lights off, overriding the timer, but this is now not the case and the lights are on all the time regardless
The ONLY way I can turn these lights off is to use the switch at the consumer unit.
Any ideas as to why this is happening all of a sudden. I suspect the timer is faulty in some way but I would still expect to be able to turn the lights off using the switch.
Just to be clear, I have not touched any wiring at all in the house which may have caused this to happen, honest.
Thanks in advance
Steve
Thanks in advance
Steve
