Hi there,
I'm changing my first light switch plate. Momentous occasion.
I'm changing a 1 gang plastic plate to a metal plate.
I removed the plastic plate and only two wires and holes in the back of the plate:
- black going into the top hole marked as TOP
- red into bottom hole which has no marking.
Am I right in thinking the hole marked TOP is essentially the COM hole which is on my new plate? And should I go ahead and put the black wire in there and the red wire in the L1 hole as shown on the new plate?
Also, the earth wire is screwed in to the actual box. I know I need to earth the switch plate too now as it's metal. Do I unscrew and strip back the current earth wire and add some more copper wire to this, screw back in and screw the remaining wire into the switch plate?
Thanks in advance.
Thanks in advance.
