In the lounge of my house there is a 3 gang light switch, each switch operating a separate light. 2 of the switches operate 2 separate wall lights on the same wall, the remaining operates the ceiling light.
I want to replace the 3 gang switch with an IR 2 gang dimmer (I think its a Varilight) and have both wall lights operated by 1 of the 2 'gangs' with the remaining operating the ceiling light.
I will be using new wall fittings with one 40W candle bulb in each. I planned on just taking the current wiring from the current wall lights and putting them into the one gang rather than the two separate of the current 3 gang switch.
Is this okay/safe? The new switch is rated to accept greater than 80W per gang so I assume it is safe but am not sure.
