Lightswitch with just 2 red wires?
10 Apr 2021
I'm looking to swap my single lightswitch over to a dimmer, but after opening it up I see there's just 2 red wires. There is an earth which is connected to a screw in the back box but that's it.
One of the red wires is connected to a terminal labelled "Top" and the other is connected to an unlabelled terminal.
I was expecting to see a neutral wire as the other switches I've changed all have neutrals. The new dimmer has 3 terminals (L1, L2 and Com).
Just wondering which way to wire this up?
I shall use my new graphic.
Aah ok I had assumed the black wires in the other switches were neutral
When you think about that statement, if it were true, the switch would be connecting the live wire directly to the neutral wire every time you closed it.
What would happen then?
Ah.. actually that's a good point... :oops:
I've always just changed switches on autopilot and never really paused to think much about it. I feel a bit silly now!!!
