- Joined
- 4 Jun 2019
- Messages
- 9
- Reaction score
- 0
- Country
Just taken over a LightSys2 panel at a farm that has never been commissioned so I assume nothing is correctly installed.
I connected it to the Configuration Software (4.1.0.008) and kept getting Thai? labels as default even though English UK is selected on both panel and software. Previously posted about another strange issue as well. Decided it was corrupted and ordered a new LightSys2 panel from Risco and fitted it.
Labels ok now and set about programming it.
Devices Installed:
IP Module
3 Keypads
Metal enclosure with Zone Expander (8) and 4A Power Supply in Remote Building.
All installed correctly and communication is 100% with the panel.
3 Magnetic door detectors on zones 1,2,3 and 4 iWise RK815DTG3 bus detectors in main building.
3 Magnetic door detectors on zones 9,10,11 and 1 iWise RK815DTG3 bus detector in remote building.
Inspected door detectors and 4.7K and 6.8K resistors used. DEOL termination of 4.7k and 6.8k set on both main panel and expander panel.
iWise RK815DTG3 unit jumpers set to 4.7K and 6.8K and dip switches set for sequential numbering 1, 2, 3.........
The result:
Zone status of 1,2,3 and 9,10,11 shows "Ready" and if any door is open it reverts to "Not Ready" as expected
Resistance sensed by panel for zones 1,2,3,9,10 and 11 all 4.7K when closed and 11.5K when open.
System is not seeing the 5 iWise RK815DTG3 bus detectors at all.
When the alarm is set, opening any door does not trigger an alarm also, alarm will set with doors open.
It is a new board so it must be a programming or wiring/resistance issue, basically finger trouble on my part. Had to leave it and will go back but I am clearly missing something obvious and hoped a fresh pair of eyes would throw a few ideas at me to solve this.
I could call David or Chris at Risco Tech but they prefer chatting, I think it best to initially list the whole setup as above and see if there is an obvious solution and if not, I will contact the tech team.
Kind regards
Stew
Devices Installed:
IP Module
3 Keypads
The result:
Kind regards
Stew
