Im doing a garage conversion (I know done to death) and I want to keep the garage door fitted and brick up on the inside as close to the door as possible so the front of the house still looks the same (a Window will go on the side). The garage floor is concrete as you would expect. I don't relish the thought of digging foundations. I want to construct a blockwork wall covering the door and then apply studwork with insulation and plasterboard. Would building regs accept this if I used lightweight blocks, I read somewhere that founds are not necessaraly needed if lightweight blocks are used, however you read all sorts of rubbish on the web.
Alternatively can anyone suggest another way? don't suppose I will get away with a thicker stud wall with a tonne of insulation?
