i am having a lightweight 3x2 stud partition 2.4M x 2.4M done to reinstate a single brick wall which used to be between a bathroom and toilet..taken out years ago and not a load bearing one.
now as a new owner i want the bath/toilet separate again to suit my lifestyle..hence the stud wall option
the carpenter is pricing for plasterboard and then i need to get a plasterer to skim coat both sides...
please..is there some boarding i can have fixed to the stud which doesnt need plastering and is wipe clean like plastic faced with trimmers at the joints
i have seen in wickes the sort of hollow click together plastic finish for bathrooms which looks ok and is sort of hollow rib..but i will be attaching mirror/cabinet/ radiator to that wall after it is finished on the bath side (on the toilet side plain wall as rad on other wall)
if anyone can suggest a better partition system i would be interested in that as well...i saw one which was metal and you clipped in finished boards into it with joint trimmers.
thanks again
yours
mrcrow..manchester
thanks again
yours
mrcrow..manchester
