I intend to replace 20mm steel conduit that has rusted in existing floor screed. It probably has two 2.5mm singles red and black probably from the 1960s.
The conduit is pretty straightforward it is just one 5m length from one side of the room to the other. But I will use galvanised this time.
My question is should I just use two singles or use regular 2.5mm T&E, the new conduit MUST remain the primary CPC.
And finally as it will be a tight fit without doing further damage to the installation. I intend extend the thread on one of length of conduit so that I use the coupler in a sliding fashion with a locknut so that I get the 5mm piece in place and then adjust the coupler.
This will leave one thread exposed (ungalvanised) how should I protect the steel? Or is there a smarter way to this?
