Limestone Hearth Bedding
8 Oct 2005
Hi chaps,
I'm helping a pal to fit their limestone fireplace next weekend (decorative only ... No fire) and this is totally new territory for me :confused:
I'm happy with tile adhesive and restraining brackets for the legs and mantle but what should I use to bed in the hearth?
I've been doing some reading and must admit that it's freaking me out a little as I keep reading about a mortar bedding mixture being absorbed into the limestone and causing staining.
Any advice gratefully received.
ESRA
i had our limestone fitted by the maker. i think he used sand / cement, but i too had heard about the problem you describe.
another company i spoke to mentioned plaster of paris.
however i am not 100% sure if that is correct.
sorry i couldnt be more helpful
You can coat the rear of what you are bedding down with PVA, this will seal it and allow you to use a lime based mortar 5:1:1 for bedding in without staining.
The 1 part lime will help with flexing in the future and the 1 part cement will give it strength.
Tony
