I have an extension being built at the moment which is going across the back on my house, the rear wall is coming down so our kitchen is being knocked through into the new extension.
We will end up with a large L shaped room consisteing of 1 part new build with proper concrete slab insulated etc...
Then there is the existing room which has the original concrete slab.
Wet Underfloor heating is going into both rooms and we were planing on putting lareg (600x600) Limestone tiles across the whole space.
However i'm concerned about the posibilities of the two different slabs moving and causing cracking along the line where the two slabs meet.
I'm worried that we will pay a fortune for the tiles and then for the installation and then get the tiles cracking if the slabs move differently.
I understand that you can build in expansion joints but i'm just trying to get advice on the best way to construct it all so we can guarentee that the floor will not move and the tiles won't crack.
One point to make is that they are planning on laying the screed across the both rooms in a single go so the concreete slabs will be separate but the screed will be a continuos piece.
I would appreciate any advice.
Should be be looking at using differnet materials rather than limestone tiles etc...
Regards
Regards
