Morning all,
I am currently painting some fitted wardrobes that I had built. So far I have primed, then filled/caulked and sanded, then primed again, sanded once more and have done two coats of eggshell. I used a brush to cut in around the edges for all coats and then a roller for the larger panel sections.
But I don't seem to be able to get rid of the line between the paint brush and the roller - not in the finish it leaves behind but in the opacity of the paint itself. It is almost like the wood is still showing through at the joins, then there is a 2 inch band of white, then a shadow in the middle part.
Was I wrong to cut in with a brush? Is it just a case of more coats until it all blends in or is there another way of evening out the finish?
Any advice very welcome.
Al
Al
