linea 24 valve
28 Feb 2007
Kent
I need to order a valve for my linea only problem is the rubbish manual has 2 different diagrams which identify the valve differently.
Underneath the boiler there is 2 similar valves one is the heating flow valve and the other is the heating return valve. The one i want is the 3 way valve which is connected to the filling loop which needs to be opened with a spanner when you want to fill the system.
As ive said the two diagrams identify these valves in opposite ways.
I have never known one of those fail!
Why do you think you need one?
Tony
I re filled the system went to close the valve and the bit you put the spanner on broke off so i cant close it now.
Also if i unscrew the filling loop water used to run out of it even when i could close it.
All the valves I have seen on those had a lever for hand operation!
Tony
I dont think i explained it very well its not that valve its the one at the other end of the filling loop after the one with the hand lever.
phone vokera and tell them your boilers serial number. then ask them for the part you need.
annoyingly they have 3 versions of filling loops and the parts list is very vague about which one is which.
