Hi, I wonder if you can help.
I have a Linea Max, installed about 5 years ago. Until last month the reliability was great.
About 1 month ago I had to replace the expansion vessel, this was done and anti corrosion and sealer was installed at the same time.
Now I have another problem:-
When the system is cold i.e. overnight, it flags a code 04 (pressure too low) the pressure gauge is reading 1.2 BAR.
When I reset the system it works OK and will work fine until the next morning, when the same thing happens again.
Any help you can give would be much appreciated.
