You should only need to line if the walls a mildly pockmarked,uneven or have patches left from flaked paint.. A lot depends on how thick the paper is..
if the wallpaper is no so thick rather thin should I use lining? The point is to get good finish. Let say walls are good but new wallpaper is thin than is better to use if is thick it might be just wallpaper. But if the walls are in bad condition rough and uneven surface is better to use lining?
Thicker wallpaper or maybe heavily-patterned thinner paper will hide minor wall imperfections,,, If youre not sure then try pasting a drop to the worst part of the wall to see if it covers nicely - if it doesnt then strip it and line
