Hi, hoping you can help.
I have some plain plasterboard of which the edges are indistinguishable as they have been taped and patched.
Would it be possible to line these walls with lining paper, I have some 1400 grade and 1000 grade already I used for another job - would either of these suffice?
Also: someone mentioned to me that I should finish the woodwork first (is new so caulk, primer, undercoat, gloss). I thought I should paper first, then caulk, primer, undercoat, gloss - that'd give me a better finish and 'cutting in' (is that what it is called?) will be easier and look better.
Hope I made that clear - thanks!
