Laying an engineered foor in my lounge/dining room. The two rooms total about 7mts long and 3 wide. However they are divided at right angles by a large archway approx 1500mm wide. The walls that form the archway are a right angles to the line of the new boards. If I start laying one side of the room I need to be sure that when I start on the other side that the boards will line up. Basically I will start laying in the lounge against the far wall until I reach the archway.Then move to the dining room against the far wall and lay until I reach the archway. The next row will therefore rum from end to end through the archway but even with the best of measurements will it line up?!
Any good ideas for ensuring it does? The plan is to not put a divider in the archway but to run straight through.
Cheers
Cheers
