A theoretical scheme at the moment- just acquired (v cheap) a woodburner that does water heating as well- it'll run up to 8 rads and domestic hot water if required. Now I'm loving the thought of getting hot water from the woodburner but don't really want to have to light a fire when I want a bath. Plus when I'm away (which is quite often) the house will cool down a lot if that was the sole heat source.
So I'm looking at gas central heating anyway- how good are combi boilers at using variable temperature supply water for the hot water side? Thinking is to use the woodburner to heat an oldschool vented hot water cylinder with header tank, the output of which goes through the combi & thence to taps. If the cylinder water is warm then it'll only need a tickle from the combi (or maybe no input at all) to get it up to temp, if cylinder is cool/cold then combi will do the necessary.
Is this feasible (without spanking a fortune on weird things), are there particular combis that are good for this trick?
Cheers
Cheers
