I need a lintel to span an opening of 1830 mm between my garage wall and the house wall. This will support the wall plate for a new pitch roof between the two.
I've had some drawings done and due to the locations of other supports in the house wall its not possible to cut into it to give the new lintel 150mm of end bearing. The drawings specify a 150mm column tied to the existing house wall which the lintel will sit on, the other end is cut into the wall over the garage. I'd like to avoid this column if possible.
I have spoken to some other people and they have said it may be possible to use a "steel" or glulam beam to span the gap without needing the support column. Is this correct? How would this beam be attached to the house wall? monty big bolts?
