Wondered if I could get some advice regarding a lintel.
In my last house I had an extension put on the front of the kitchen and when I asked how we could disguise the original lintel for the then removed window the builder suggested that we remove it completely and change it to steel RSJ that he 'hid' up higher between the kitchen ceiling and first floor floorboards.
I have now moved and instead of needing an extension this house has actually already got a flat roof extension on the back of the kitchen which I would like to knock through from the kitchen to this room.
The original builder has taken a look and is saying its possible but doesn't seem keen on doing it. Is this type of work tricky or should I offer it to other general builders to see if they can quote for it.
The other question is that on the last house the extension was part of planning permission so as part of the drawing work done the architect als done load drawings and worked out the steels needed so that it complied with Building Regs. Can I ask who would do this for me this time and im guessing this would also need planning permssion??
Thanks in advance
Darren
Thanks in advance
Darren
