Lintel
22 Mar 2025
Hi. Looking for a bit of help if possible please. Im going to build a block garage at home , Its single skin with 140mm block. I need a lintel for the garage door opening which is going to be 3600 so presume will need a lintel 3900. What type lintel should i use to span this length ? There wont be much load on it just 2 courses of 140mm block above. The roof sits on a separate steel frame. Any advice much appreciated
Is the wall going to be rendered?
Thanks Tony , Would it be ok the 140 block overhanging with it only being 133 ?
Thankyou
The problem with using angles is that they can rwist under load, particularly on long spans.
A bit risky I would have thought.
If the roof is independant and you're going to clad the thing why not a timber solution.
You could create a truss essentially and that would save you a lot of effort.
