Hi all,
Seems that Building Control are always very keen on lintels over any pipes going through walls. That's all well and good, but what happens when the pipe is going through a footing? I've got a gas pipe about a foot down (in metre-deep footings). BCO told me to leave about an inch gap around, and put a lintel over it. Yes, I did say that it would be going through the footings!
So what's the normal procedure here guys? Cut up an off-the-shelf concrete lintel into little pieces to make 450 width? Use bricks as lintels instead? Wrap the thing in a bit of split plastic pipe? It would be nice if it were possible to get the pipe out later if needs be, so I'd like to avoid wrapping it in tape and just embedding it in the footings.
Appreciate any advice.
