I have read quite a few threads, but haven't come across this question.
I'm putting a travertine floor in my bathroom, which is at the moment is normal floorboards with very thin hardboard over the top. I realise that I need to put plywood down first, then flexible adhesive and grout.
My questions are what is the minimum thickness of ply I should use on the floor, and how do you 'finish' the inevitable step from the floor which has plywood, then adhesive then thick tiles, to the normal carpeted hall?
thanks
thanks
