Hello all – some advice welcome.
I have an existing kitchen floor – concrete slab, no DPM or insulation. I need to bring it up to a new level which is 18mm higher than its current level. Within that 18mm I would like to:
Install a Liquid DPM (as per instruction on forum)
Lay a foil to reflect heat
Fit an electric heating element
Finish for limestone tile
Given the DPM instruction I’m thinking that the most appropriate method would be to:
If so - I’d welcome people’s thoughts and advice on which products that would be most suitable for both levelling compounds and heating element.
thanks
Phil
- Clean/dry concrete slab
- Prime with watered down p131
- Self level with acrylic to depth of 8mm
- Apply 2 costs of DPM
- Prime again
- Lay foil
- Lay heating element
- Self Level, burying heating element to required level using a latex levelling compound
thanks
Phil
